Laser/Router Combo
jcsb
CNC Control System Serial Number: 929110276
Laser/Router Combo
Post by jcsb »
I'm installing a OBT laser to my router and after reviewing the schematic S15061, is it possible to share output 4 for laser enable and spindle forward? I'm using a rev. 3 board.
John
Re: Laser/Router Combo
jcsb wrote: Sat Aug 28, 2021 2:25 pm I'm installing a OBT laser to my router and after reviewing the schematic S15061, is it possible to share output 4 for laser enable and spindle forward? I'm using a rev. 3 board.
Do you not have any other spare outputs?
Gary Campbell
Post by Gary Campbell »
Not very likely that you can share the those terminals. Switching signals from 2 different voltage sources on the same terminals will cause problems. That said, you could use your OP4 to drive a small 4 pole relay that uses 2 contacts for the spindle, and 2 for the laser.
