M15 macro coding
alimumtaz101
M15 macro coding
Post by alimumtaz101 »
Hi everyone,
I am making a milling machine and as far as now everything is pretty smooth and solid.
Now i am working on rack type ATC and i am almost done with it but, i am person of understanding rather than copy and paste.
below is the M15 built-in macro of centroid acorn (for the tool changer), I have completely understood the code of M6, and M16.
I am just confused in the one line of M15 code which I mention below.
can anyone tell me what this is and what is this IF (#9402 != 0), what is this #9402, I tried to find it in the manual with no success.
thanks
;M15 Macro
(IF #50010 ;Prevent lookahead from parsing past here
N100 ;Insert your code between N100 and N1000
M94 /15 ;Turn on ToolUnclamp request
IF (#9402 != 0) THEN GOTO 200
G4 P3 ;Wait 3 seconds
GOTO 1000
N200
M101 /70012 ;Wait until tool is unclamped
N1000 ;End of Macro)
Re: M15 macro coding
alimumtaz101 wrote: Thu Jul 22, 2021 1:09 pm Hi everyone,
thanks
;M15 Macro
GOTO 1000
N200
You had posted this to the success stories Forum. I moved it here to the Acorn forum.
Please post a report, Which motion controller are you using?
Variables 9000-9399 correspond to parameter values 0 - 399. Parameter 402 does not currently have an official function assigned so without knowing more about your machine, I can't tell you much more.
Program values are described in Chapter in the CNC12 user's manual: https://www.centroidcnc.com/centroid_di ... -v4.14.pdf
Parameters are described in Chapter 15.
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
Tom, param 402 does have a function assigned in v4.64 (and v4.62 but not v4.14 to which the manual refers) which states "Axes paired enabled". My router shows a param 402 value of 0 correctly indicating Not Enabled.
I posted this reply to Ali on the Facebook group but cannot fathom how this would affect his Auto chuck operation
Hope this helps
Nigel
The manual description is out of date.
Variables #9000 - #9999 correspond to Machine Parameter values 0 - 999.
Variable #9402, then, retrieves the value of Machine Parameter 402.
From context, it appears that whoever wrote the macro intended that Parameter 402 be used to show whether there was a tool-unclamped confirmation switch, which the PLC program would be responsible for echoing into MEM12 (#70012). Apparently that proposed use was never documented, and was never communicated to whomever decided to use P402 for axis pairing instead.
Interestingly, P402 is also absent from the only documentation that appears to apply:
https://www.centroidcnc.com/centroid_di ... meters.pdf
alimumtaz101
Hi marty,
Thanks for moved it here, regarding the report i am not at workplace here is 5 days off, i am just reading the code and manual and understanding everything. And also report doesnt matter because as i told i am not getting any error, just was confused about this line that what was the purpose of it since this not mentioned anywhere.
I am using acorn with 4.6 version also have ether1616 connected, they machine is completly diy milling machine have 4 axis. Everything is working fine till now.
alimumtaz101
As nigelo mentioned me on facebook regarding this parameter for the axis paired, but i think after reading cncsnw comment this line of code is useless for me, if i remove it so it will not effect anything (will try), because i think this line had never executed in any ATC attempt.
One question what is this paired axis means, does it use when we have slave axis?
alimumtaz101
; Filename: mfunc15.mac
; Description: Tool unclamp macro
; Notes:
; Requires:
; Inputs:
; ToolIsUnclamped IS INP2
; Outputs:
; ToolUnclamp IS OUT8
above is the description of the m15 macro, and I am confused why it is mentioned there and advise to declare inp2 in the wizard as ToolIsUnclamped.
since this INP2 is never used in the coding, I know I can use it if I attach one sensor on my jack, nd write m101 for INP2.
but instead of this i found this #9402 with MEM12 bit of plc to wait till change of state.
please post a fresh report.zip
