"shot pin tool change orientation"
I Need help, PLC M19 Macro in Acorn CNC12 to control shot pin tool change orient.
anybody has done on anyone of this cnc system tool change orient?
Re: "shot pin tool change orientation"
More information about the machine, the tool changer, pictures of the shot pin and microswitches etc.Apolo1969# wrote: ↑Mon Jul 19, 2021 6:37 pm I Need help, PLC M19 Macro in Acorn CNC12 to control shot pin tool change orient.
Tool changing is a process.
Please take the time to provide more information.
marty is correct need the details on your project to help effectively,
in general how to activate an output via macro is covered in the macro programming guide.
my machine is a Haas v1 and here the documentation of the shot pin
- haascnc.com-Spindle Drive - Troubleshooting Guide - CHC.pdf
- (1.04 MiB) Downloaded 82 times
If I had a client ask to refit a HAAS VF1, I would be using All in One DC (if it had good DC Brush motors) or Centroid OAK and new compatible Servo Drives.Apolo1969# wrote: ↑Fri Jul 23, 2021 3:15 pm my machine is a Haas v1 and here the documentation of the shot pin
You have posted in the Acorn forum. It could be done with an ACORN and ETHER1616. In any case you would need some help modifying an umbrella PLC (Assuming you have an umbrella style tool changer and not a swing arm)
More details about the build, if its to be used in a hobby or commercial environment, what spindle drive you have etc, would be helpful.
I assume the HAAS control is dead? What's the status/condition of the machine. What are you hoping to accomplish? "End game"
i bought the machine strip out and im going to use Yaskawa v1000 VFD, dmm servo motors. the machine has an umbrulla type tool changer just like Bridgeport torq-cut 22 the umbrella is rotate by ac motor
ILL use this machine for personal use, not intented for commercial use.
OKAY,Apolo1969# wrote: ↑Thu Jul 29, 2021 9:27 am i bought the machine strip out and im going to use Yaskawa v1000 VFD, dmm servo motors. the machine has an umbrulla type tool changer just like Bridgeport torq-cut 22
You will need to retain Centroid to help modify the Umbrella ATC PLC for you. Go here if you haven't already: viewtopic.php?f=60&t=3397
Search for ATC, you are looking for the ATC Mill Carousel option.
Make double sure you work closely with DMM on selecting the CORRECT size AC servo motors.
You will need a line reactor capable of the load of all your DYN4 drives. I assume Z has a counter balance?
Yaskawa V1000 should work out.
dmm servo for X and Y are 1KW And Z axis 1.8kw.
yes the machine has gas counter balance but they are not good gas is gone im going to use Z-BRAKE
You will likely need a regenerative resistor on the Z axis DYN4.Apolo1969# wrote: ↑Thu Jul 29, 2021 9:37 am dmm servo for X and Y are 1KW And Z axis 1.8kw.
Jump over to this thread, and subscribe to it: viewtopic.php?f=64&t=5670
Similar question was asked about shot pin. I've asked the fellow to post his report. The report contains all the macros and the PLC SRC file that might help you.
