Teknic SDSK HLFB brake control issue (Resolved)
Posted: Fri Jul 09, 2021 8:20 pm
Hello all,
Need some advice on how to handle Z axis sliding after shutting down CNC12 application or upon Power Up.
I am using Teknic SDSK servos on all my axis. Double drive Y axis with master and slave setup, X and Z single drives, with Z axis utilizing 24V brake assembly. The control of Z axis brake is tight to HLFB output of Z axis Servo motor (according to Teknic’s manual page 59) to assist holding position while there is no movement on Z axis. Everything seems to be working fine, but I found that during shutdown process of CNC12 software and after launching CNC12 application, when status of all my servos is OFF(solid amber led), the Z axis brake gets energized, thus releasing Z axis, which slides down as a consequence and looses its position. If I physically disengage the brake power from HLFB pin from SDSK servo motor before CNC12 application and click MDI soft button, then all servos get into idle status (flickering green) at which point I can connect the brake circuitry to HLFB pin and maintain Z axis position without loosing it, but at this point servo motor is capable of holding the position on its own.
In ClearPath -MSP V2.0 application I am utilizing HLFB (High Level Feed Back) All Systems Go option. There are additional options under HLFB setting that are available, but didn’t seem to help me to accomplish the Z brake engaging/disengaging properly. When I set HLFB mode to Servo On mode the brake is not energizing to release the grip when there is a movement command to Z axis from control board.
Options available are:
Servo On
In Range-Position
Measured Torque
All Systems Go (ASG)-Position
ASG-Position, w/Measured Torque
ASG-Position-Latched
ASG-Position-Latched, w/Measured Torque
I would appreciate if anyone who experienced such problem can shed some light onto how to overcome this issue. Currently I installed the latching switch to disengage the brake circuitry on startup and shutdown of CNC12 app to work around it.
P.S. At the present time HLFB circuit mode that I use causes a relay flickering in ramping motion if I choose slow DOC (depth of cut) or shallow angle.
Servo On
In Range-Position
Measured Torque
