Scaling issue when importing .DXF
Eric V
Post by Eric V »
I exported a .dxf from Fusion 360. When I loaded it into
CNC12, the part was scaled. Original in Fusion 360 was 2 inch x 4 inches.
In CNC12 the part is 5 inches x 10 inches. Is there a way to correct the
scaling? (report attached)
report_E415F6F2C31C-1202204159_2021-05-18_18-44-00.zip
(611.04 KiB) Downloaded 68 times
Re: Scaling issue when importing .DXF
For some reason, Fusion exported your part as metric and CNC12 imported it in inches scaling it by 2.54. Check your F360 units.
Eric V
Post by Eric V »
Hi Tom,
Thanks for guiding me in the right direction. It seems when Fusion 360 is exporting
from the cloud, the units are metric. The Fusion 360 forum has some suggestions
I will pursue.
Thanks again!
