New AjaxCNC Tech Bulletins added 3-18-13
fyi... several new Tech Bulletins have been added to the AjaxCNC covering PC requirements, new voltage ratings on our Servo drives (now up to 180 volts!) and other good installation information..
http://www.ajaxcnc.com/ajax-technical-bulletins/
Re: New AjaxCNC Tech Bulletins added 3-18-13
Is there an updated list somewhere? This stops back in 2013 and I have TSB 296 on setting up a spindle load meter so there are quite a few missing.
tom, hello. the tech bulletins have been getting updated. just the date on the ajax web page was not being updated when the tb was updated but the link still would take you to the latest TB. and i've asked liviu to update the list thanks for pointing this out. we are working on a new "Centroid DIY" web page that will replace the ajaxcnc.com web page that will make things easier for everyone.
in the mean time here are direct links to
tb 296 load meter
http://www.centroidcnc.com/dealersuppor ... ds/296.pdf
tb 295 sigma 1 and 2
http://www.centroidcnc.com/dealersuppor ... ds/295.pdf
tb 292 installing a scale for dro use
http://www.centroidcnc.com/dealersuppor ... ds/292.pdf
289 soft travel limits
http://www.centroidcnc.com/dealersuppor ... ds/289.pdf
288 allin1dc settings for 3rd party servos
http://www.centroidcnc.com/dealersuppor ... ds/288.pdf
286 trouble shooting drive motor voltage supply
http://www.centroidcnc.com/dealersuppor ... ds/286.pdf
285 motor doesn't move no error, no fault
http://www.centroidcnc.com/dealersuppor ... ds/285.pdf
283 tweaking windows 8 for cnc control use
http://www.centroidcnc.com/dealersuppor ... ds/283.pdf
281 encoders not couting, dro does not update
http://www.centroidcnc.com/dealersuppor ... ds/281.pdf
278 setting up a Control Techniques SP spindle drive
http://www.centroidcnc.com/dealersuppor ... ds/278.pdf
Best regards, Keith
ajax tech bulletin page has been updated.
Thanks, Keith. Can't wait to see the new Centroid DIY website. My Oak board should be here soon and I'm looking forward to jumping in.
Sportbikeryder
CNC Control System Serial Number: 10583
Post by Sportbikeryder »
Hmmm....the spindle load meter just gave me an idea. I'll have to check the vfd specs in the cabinet. The system is cnc10, but if it has an analog output on the vfd no reason I couldn't add a separate indicator somewhere. 8-)
yeah. you can always buy a little analog volt meter and use the analog output of the VFD to run the meter. check your vfd, often its 0-2 volts vdc output for load... so just buy a volt meter in that range.. and wa la you have a spindle load meter the old fashion way.
