Upgrading 1984 Wells Index 820 with Allin1DC
Re: Upgrading 1984 Wells Index 820 with Allin1DC
What page are you on?
Are you following along in my video series?
You can mix encoders. Yes, you change the appropriate axis encoder count. If you use a 2500line encoder, then your entry would be 10,000
Chevy427z
CNC Control System Serial Number: A900999
Post by Chevy427z »
martyscncgarage wrote: Mon Jun 14, 2021 7:56 pm What page are you on?
I am at page 32.
Yes
My next step is to get this encoder issue solved by replacing the one that is not working on my system. I'll be ordering the 2500 line one that polar helped me pick out. Once I get that installed, I will go back to square one..... again.
M400
A900999
CNC12
Chevy427z wrote: Tue Jun 15, 2021 3:59 am
I am at page 32.
Yes
Encoder test only requires you to have All in One DC powered up so that it can provide power to the encoders. PID screen will show you the encoder counts as well as the Asterisk next to the axis letter. The * is the index pulse. Turn the shaft slowly.
Chevy427z
Post by Chevy427z »
Success!
All encoders working properly.
Just have to fab an adapter for the new encoder from automation direct. I had a hard time reading their drawing specs, I thought this would bolt in. Oh well, that's an easy fix.
Can someone confirm that I don't need the blue wire on the new encoder (0 V) ? Working fine without it.
Onward and upward.
report_0008DC111213-0301212560_2021-06-17_15-31-53.zip
(478.33 KiB) Downloaded 69 times
M400
A900999
CNC12
Yes, you should wire that 0V to COM
You have 8 wires and the shield. The shield carries through and eventually gets soldered to the DE9 shell
Chevy427z
Post by Chevy427z »
Thank you Marty! Will do.
M400
A900999
CNC12
Chevy427z wrote: Thu Jun 17, 2021 5:24 pm Thank you Marty! Will do.
With encoder signals, you want good solid connections.
I think you bought some of the appropriate encoder cable too correct?
Chevy427z
Post by Chevy427z »
martyscncgarage wrote: Thu Jun 17, 2021 5:38 pm
Yes I did!
Mark
M400
A900999
CNC12
Chevy427z
Post by Chevy427z »
I've been doing a lot of reading and watching Marty's videos in preparation for the next steps and I have a few preliminary questions.
The machine has been sitting for a few years so I wanted to make sure that the oiling system was working before I actually moved anything with the servo motors. I'll have some specific questions about that system later.
About the servo motors, I understand their theory, though I haven't been able to figure out exactly how the ALLinOne will move them. Do they operate on varying voltage (is that what controls the speed of their feed)? And how can I determine what voltage I need to drive them? I found a rectified 24 volt source (in the system that I am replacing) and drove them briefly back and forth just to see them move on their own. I don't have a lot of information on them (see the pics for numbers).
Edited: Also, the instructions and videos talk about "shielding" for the servo motors. My current system does not have that in the two wires connecting them to the old controller. Do I need to upgrade those wires, too?
Page 36 talks about "electrically configuring" inputs. How do I determine what I need? 5, 12, or 24?
Why is there a choice between "sourcing" and "sinking". I understand "sourcing" better as it relates more to automotive and household wiring, which I'm more familiar with.
Plenty more questions to follow. Thank you.
edited: forgot to include the pics of the servo motor labels.
M400
A900999
CNC12
