Here is a DIY pendant... This is me just explaining on how I did this. I will link the two videos that you will need to watch along with the parts that you will need.
Really this is making a keyboard then just mapping the keys for the specific key combos that are setup for Acorn. It would be great if cnc12 had a plug in for joystick inputs then the joytokey software wouldn't be needed. But for now this will work.
reWASD will not work.. I tried this first. The reason why it will not work is because it is looking for a legit (commercial) controller.
Parts you will need:
Adruino Pro Micro (Pro mini will also work) :
https://www.amazon.com/KEYESTUDIO-Micro ... 942&sr=8-6
Buttons:
https://www.amazon.com/gp/product/B07XB ... UTF8&psc=1
Rotary Encoder:
https://www.amazon.com/gp/product/B08BF ... UTF8&psc=1
22-24 AWG wire.
How to make the button box:
How to map the buttons:
Software needed to map the keys: https://joytokey.net/en/
DIY Pendant
Re: DIY Pendant
Thanks for sharing the information.
You are correct, all you need is a keyboard emulator controller and assign those keys to the Centroid Keyboard Short cuts
Re: DIY Pendant
fyi.. with a few simple plc program mods you can use acorn/ether1616 inputs for joy stick control for jogging an axis
