Difference between router and mill
LenelyWolf
Post by LenelyWolf »
Hi
I’m just installing centroid on my new pc. What differences it will make if I chose between mill and router. Is it just for simulation purposes or VCD or does it make any difference in gcode? I’m building router for milling steel and aluminium
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Re: Difference between router and mill
Post by Nigelo »
Hope this helps
Nigel
LenelyWolf
Nigelo wrote: Fri Mar 12, 2021 11:20 am viewtopic.php?f=60&t=5556&p=47579#p47579
So as far as I understand from that link router is a dummer version of mill. Am I right?
Nigelo
Post by Nigelo »
Keith's summary, on the link I posted, clearly states the differences in configuration.
Edited to say the base software is identical and can be configured to however you wish. No change in G Code or Intercon programming
Hope this helps
Nigel
LenelyWolf wrote: Fri Mar 12, 2021 11:31 am So as far as I understand from that link router is a dummer version of mill. Am I right?
No, the mill version is dumber because the router guys are smarter and we know how to spell. :mrgreen:
