New centroid servo cable question
Craig
CNC Control System Serial Number: A900928
Post by Craig »
My new servo cables showed up from Centroid, they have 3 wires and what I’m replacing has 5, I show 4 in the picture, what’s not seen is the ground wire.
How does this work?
Re: New centroid servo cable question
Centroid does not use the tachometer, so you can ignore the thin white and black wires.
Craig
Post by Craig »
Excellent thank you!
I suppose Centroid sells the male version of the female end they sold me
Craig wrote: Sun Feb 21, 2021 9:32 pm Excellent thank you!
That connector mates with Centroid Servos.
You can cut it off and use insulated spade connectors on the -/+ wires and use a ring terminal on the ground wire.
You can also get the mating housing and contacts from Digikey.
