Acorn CNC12 Mill, Router, and Lathe v4.64 has been released! < v4.80 has superseded v4.64>
Hot fix Acorn CNC12 v4.64 Mill, Lathe, Router has been released. 3-15-21
All related documentation can be found here.
These videos were made for v4.5 but also apply to v4.6.
Acorn New System Installation Video
Update from older version...or from Mill to Router
1.) make screen shots of existing Wizard screens, make a fresh report.zip file
2.) rename existing cncm or cnct directory
3.) follow video above and install
4.) Use the new Wizard to set up the machine configuration, press write settings to cnc control and follow instructions, then install license file.
5.) If desired, copy G code programs, Intercon program, tool library, WCS file, any custom macros, from old cncm or cnct directory. reboot cnc12
tuffduck
Re: Acorn CNC12 Mill, Router, and Lathe v4.6 has been released!
Post by tuffduck »
I just installed and all went well.
report_0479B7E7BDC2-0205202948_2021-01-28_19-53-36.zip
(1.85 MiB) Downloaded 322 times
MountainMetal
Post by MountainMetal »
Fantastic! Will install when I get back to the shop.
MountainMetal
just installed and when it started said it was updating firmware and about 5 minutes later said it could not connect to Acorn board. Help!!
MountainMetal wrote: Sat Jan 30, 2021 4:40 pm just installed and when it started said it was updating firmware and about 5 minutes later said it could not connect to Acorn board. Help!!
power cycle, do you have a heart beat?
found a crash when probing Bore cycle is finished and you hit ECS , this causes cnc12 to crash.. will have hot fix soon. in meantime use Rolands probing app as a alternative bore cycle. :-))
MountainMetal
cnckeith wrote: Sun Jan 31, 2021 3:50 am
I had a heartbeat till I powered cycled, now no heartbeat. I have tried to reflash the board with no success. When I apply power with card in and user button depressed The boards power light comes on but the files do not load. The 4 lights do not light up at all. Here is the last report I had with the beta. There were none in the new cncm folder.
report_E415F6F10926-1119204062_2021-01-30_13-25-43.zip
(788.22 KiB) Downloaded 248 times
MountainMetal
MountainMetal wrote: Sun Jan 31, 2021 5:59 pm
I had a heartbeat till I powered cycled, now no heartbeat. I have tried to reflash the board with no success. When I apply power with card in and user button depressed The boards power light comes on but the files do not load. The 4 lights do not light up at all. Here is the last report I had with the beta. There were none in the new cncm folder.report_E415F6F10926-1119204062_2021-01-30_13-25-43.zip
OK! Picked up a usb card reader and when I got home plugged into my office computer and the Hp format utility ran OK on that computer, was using an onboard card reader on a computer at the shop, reformatted and loade files onto card and the BBG took the files this time. Weird and I don't drink. I'll plug it in tomorrow and see what blows. Ha Ha!
Caleb
CNC Control System Serial Number: 780473A2EE6C-1022192587
Post by Caleb »
Could there something on the new version that may be causing the 944 mpu request resend and 946 pc resending errors? There seems to be more of it in people's fault logs?
I'm not asking for help so not posting a report yet...
MountainMetal
Caleb wrote: Mon Feb 01, 2021 3:41 am Could there something on the new version that may be causing the 944 mpu request resend and 946 pc resending errors? There seems to be more of it in people's fault logs?
First run after finally getting up and running and mine is loaded with them, almost continously,
