No step and direction signal?
Hbjj1
Re: No step and direction signal?
Post by Hbjj1 »
Also should I connect one of the acorn com ports to ground
Right now its just connected to the power supply as shipped
Follow the Centroid Schematic for the G203V to DB25
S14978-ACORN_rev4_GECKO_G203V_STEPPER_DRIVE.pdf
(193.2 KiB) Downloaded 117 times
Difference between the Header terminals and DB25 connector is that the DB25 pins are at 5VDC logic.
IF you want to try and connect the G203V to the headers follow the legacy schematic which requires the resistors
S14891-ACORN_rev3_GECKO_G203V_STEPPER_DRIVE.pdf
(135.28 KiB) Downloaded 149 times
Hbjj1
Post by Hbjj1 »
Ok thanks I will get a breakout board
Richards
Post by Richards »
The DB-25 breakout board is the best option. If you're curious, here is a simple schematic of how I wired a G203v using the Hx connectors: (Please note that the resistors are 2 WATT)
-Mike Richards
Hbjj1
Post by Hbjj1 »
Thanks for that
I used a old db25 end and soldered my own wires
I assume that the pin map in centroid 4.5 is looking at acorn
The pin numbers are what you pay attention to. If you look closely at your connector, each pin is numbered.
Hbjj1
Post by Hbjj1 »
That worked i have motion
Great!
Kirk_Thomas
Post by Kirk_Thomas »
Can the DB25 be used with the V3 Acorn board? My Acorn does not have LED's on the inputs, so I guess it's a V3. But I have a db25 BOB. Which should I use? The H4 and resistors or the DB25.
CNCMaryland
CNC Control System Serial Number: F045DA7CBF8b-103011290
Post by CNCMaryland »
Yes you can use the DB25 on a V3 board that is what I have.
The easiest way to get up and running fast, for anyone reading this, Gecko G540 to DB25. The G540 has DB9 connectors. You can get steppers with the DB9 wiring, and it almost gets to a plug and play system.
