Backlash compensation
Christian Wahl
CNC Control System Serial Number: 0479B7ABD46B-0319203088
Post by Christian Wahl »
Hello
Is it possible to compensate backlash in just one direction? negative or positive Z direction
I want to mount steppermotor to the quillfeed on my mill and got backlash just in one direction because of springload/tention on the quill feed axel.
I know it is not the best solution, but i will mount Z feed on the knee at a lather stadium.
Btw it is a Bridgeport j-head mill
BR Christian
Bridgeport J-head retrofit
Just for fun
Re: Backlash compensation
Yup. Backlash tables have independent values for positive and negative directions.
Muzzer
Post by Muzzer »
Thinking about the physics of this situation, presumably the effect is not backlash as such - more likely to be either stiction and/or elastic behaviour. Interesting to understand how backlash would be different in 2 directions.....
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
If you intend putting the quill under stepper powered axis control, surely you no longer need a strong spring return as the stepper will lock the quill in any position when at rest. This renders the return spring redundant and the quill may or may not be to one side of the lash. In that case, adjust the spring tension to achieve approx neutral buoyancy. You can and should then set the backlash in the conventional way
Hope this helps
Hope this helps
Nigel
