Rls encoder and vfd calibration
- CNC Control System Serial Number: 0113202827
Hi folks, after reading this thread on the forum : viewtopic.php?f=60&t=4043&p=33003&hilit ... all#p33003
I decided to go this way with my Taig mill and lathe with glockcnc spindle and motors.
I ordered and installed the encoder and ring from RLS (encoder RLC21ca06b and ring MR047B).
report_4C3FD31F8733-1212192740_2020-10-16_08-00-33.zip[/attachment]
I'm having problems getting the motor to match the commanded rpm speed. I've read every documentation and forum posts I could find and can't get it to work properly, So I thought you guys could help.
Here is my problem:
By playing with the Max spindle speed in Acorn against the maximum rpm in the motor driver i can tune it to match any speed, let's say 5k rpm (50%).
When doing so, anything above goes too fast, anything below goes too slow. Acorn Voltages outputs have been tested and are correct.
To fix this I would have to find the "bias" or "gain" on the vfd as suggested in the Acorn documentation:
My vfd and motor are from Glockcnc.com, it seems to be a generic Chinese vfd with a very badly tanslated manual and I can't find a parameter that would help my problem.
the Analog input dead band P1。12 doesn't help me to bias. I called Glockcnc but he couldn't help me, he has to contact the factory in china and that'll take a while.
the minimum spindle speed in Acorn didn't help me either.
I was wondering if there was parameters somewhere in Acorn that I could play with, that would help me skew things the right way?
Any other ideas?
Also, one last question, is it normal for the encoder reading to fluctuate constantly in Acorn? for example it goes from 5001 to 5003 to 5005 rpm several times per second.
Thanks folks.
Here is my problem:
Any other ideas?
Thanks folks.
Re: Rls encoder and vfd calibration
AFAIK, there are no parameters in CNC12 to modify the DAC output, you would have to modify the DAC section of the PLC if you wanted to add slope control from the Acorn side. Not a very capable VFD if there are only 14 parameter to control it. Can you post the complete VFD manual?
It is not uncommon for the motor speed to vary a percent or two when controlled with a VFD.
yah, cheap vfd it seems.
here is the "manual"
https://s3.amazonaws.com/precisionmachi ... Driver.pdf
That is not a VFD. That is a brushless servo drive....nicolasjolliet wrote: ↑Fri Oct 16, 2020 12:03 pm yah, cheap vfd it seems.
It also looks from the wiring diagram that it uses 0 to +5VDC for control, not 0 to +10VDC
There will be tuning involved since you are trying to run a spindle with a servo drive......
I assume you cant get help from the manufacturer?
No help from the manufacturer. I called James at Glockcnc and he couldn't help me, he has to call the factory and that will take some time. James said he didn't have this problem before and that it works with acorn.
Also I saw the 0 to 10v here in the manual, it's weird because if you use a pot you use 5v, even though the sv takes 0 to 10v.
"Functions1. Speed adjustment methodThis driverprovide below threeadjust methods for the user to choose:Analog voltage adjustment speed: the terminalsof external potentiometer connect tothe +5v terminalin signal control and COM, connect the regulator terminal to SV, not only make it possible to adjust speed by external potentiometer(10K~100K), but also can achieve speed adjust through other control unit(Such as PLC,Microcontroller, etc) input analog voltage to SV. The acceptance of SV is DC 0V~+10V, and the corresponding motor rotate speed is 0 to rated speed.
You also can use external digital signal to adjust speed: apply PWM with 5V amplitude and 1KHz~2KHzFrequency between SV and GND to adjust the speed. The motor rotate speed will adjust by the duty radioliner adjustment."
maybe I can make some sort of a voltage divider to half the acorn output?
Check the KBSI240D manual, it may allow the output to be 5 OR 10vdc
Thanks, I’ll check it out.
But I think my driver takes 10v as I would get the maximum speed when sending 10v. I’ll try to send 0-5v with an external dc power supply and see.
I got an email from Glockcnc, he says the manual takes 0-5v, but this one was made special for glockcnc, and it takes 0-10v.
onward....
I really don't know what to do at this point.
onward....
Sorry, getting you confused with another user.
There must be a setting in the drive to allow TOP speed to be set. That TOP speed I would expect to be met when 10VDC is applied to the drive input.
Then the issue is what the actual spindle speed is. Then adjusting that top speed value in the drive until the expected spindle speed is met.
Its all I can think of...
Ok, thanks Marty.
the top speed i can set, it's the bottom speed i need to set in order to have a linear line at 45deg.
so if I set 5k to 5k, so 1k is 1k, 8k is 8k as well.
