Page 1 of 2
BIOS password (Resolved)
Posted: Sat Jan 07, 2012 4:33 pm
by Maint_1
I was attempting to upgrade one of my CNC10 units to MPU11 today. It would not allow recognize the new SSD I used to replace the CFD it orignally came with. When I attempted to trouble shoot the problem by editing the BIOS it would not let me in as it needed a password. Is there a standard password that Ajax or Centroid uses? Was this a one time anomally, I have one more to do. I should mention that I've already done one upgrade and didn't run into the problem. I got past it today by clearing the CMOS but I'd like to avoid that if at all possible.
Re: BIOS password
Posted: Mon Jan 09, 2012 12:05 pm
by Centroid_Liviu
I sent you a PM with the password.
Re: BIOS password
Posted: Sun Mar 08, 2020 4:46 pm
by PubliSignsUSA
I have an error code on the Lenovo on the CNC:
I need the BIOS password to get in to do the following:
ERROR 1962 Lenovo – No Operating System Found
what is the password so we can installa new hard drive? Thanks, Gerard
Re: BIOS password
Posted: Mon Mar 09, 2020 9:16 am
PubliSignsUSA wrote: Sun Mar 08, 2020 4:46 pm I have an error code on the Lenovo on the CNC:
This is YOUR PC I assume? Centroid won't be able to help if they did not supply the computer.
Please provide more information about the control, post a report or the serial number on the back of the Operator console or the cabinet.
Typically if there was a password on the Bios (TERRIBLE IDEA) I try removing the battery from the motherboard for 30 minutes or so and then reinstalling it (might be a good time to replace with a new one). Generally that will reset the BIOS to defaults. Its usually a CR2032. Looks about the size of nickel-ish
Re: BIOS password
Posted: Mon Mar 09, 2020 10:43 am
by PubliSignsUSA
Centroid did provide the PC. They responded already this am with the password.
I hope that installing the new SSD hard drive with Widndows 8.1 and the OAK, ALLin1DC and MPU11 will suffice and that I have no other configs to do.
Thanks, Gerard
Re: BIOS password
Posted: Mon Mar 09, 2020 10:50 am
PubliSignsUSA wrote: Mon Mar 09, 2020 10:43 am Centroid did provide the PC. They responded already this am with the password.
Thanks, Gerard
Thanks for lettin us know!
What are you working on incidentally? What control do you have?
Re: BIOS password (Resolved)
Posted: Mon Mar 09, 2020 10:58 am
by PubliSignsUSA
We have a Lenovo C460 pc on top of the PLC. We have an M39 controller. G
Posted: Mon Mar 09, 2020 11:08 am
PubliSignsUSA wrote: Mon Mar 09, 2020 10:58 am We have a Lenovo C460 pc on top of the PLC. We have an M39 controller. G
Post questions here if you need further help. IF you can, post a report file...
New build or existing/retrofit upgrade?
Posted: Mon Mar 09, 2020 11:12 am
by PubliSignsUSA
I had an existing 3 axis CNC machine retrofit and upgrade in 2015, the hard drive on CPU crashed.
Posted: Mon Mar 09, 2020 11:21 am
PubliSignsUSA wrote: Mon Mar 09, 2020 11:12 am I had an existing 3 axis CNC machine retrofit and upgrade in 2015, the hard drive on CPU crashed.
Got it. I hope you had a report file saved on a USB stick ;)
