Acorn time base turret Emco 5
Jr914
Post by Jr914 »
I have a problem with setting up the turret control. No output from output 2 when a tool change is sent (MDI). Use the schematic from Acorn CNC site. Also notice that all references is for version 4.1 I am use the latest 4.5 CNC12. Also no assign name to #2 output or input. Using a proximity sensor for homing of the tool turret. (High 24vdc when closed). Also I have read all post in reference to the time base sensor. Another thing Marty mention a zip file needs to be loaded is this still needed with ver. 4,5? If so where can I download this zip for the PLC?
Jr914
Re: Acorn time base turret Emco 5
Post by Jr914 »
My rerport file couldnt get it to up load with my I pad.
report_0CB2B7D433C8-0701203466_2020-08-04_15-10-47.zip
(569.35 KiB) Downloaded 122 times
They are in the Knowledge Base Forum. Top of the page:
viewtopic.php?f=63&t=1340
Your sensor needs to SINK the acorn input to ground (NPN not PNP)
(Been awhile since I did that video, make sure you use the correct voltages to the turret motor)
Jr914
Post by Jr914 »
Thanks for the information Marty I will try it out tomorrow. How is that Hot Rod coming along? 😀
Jr914 wrote: Wed Aug 05, 2020 11:28 pm Thanks for the information Marty I will try it out tomorrow. How is that Hot Rod coming along? 😀
Good luck....read the instructions that should be included with the package.
Starting to work on brakes today...hopefully. Have a bit of Centroid testing to do....
Jr914
Post by Jr914 »
Well everything seems to work with the exception of MDI tool change command. It will index to home with the MDI M18 Command and the index button on the control panel will advance the changer forward one position.
Any ideas what I am doing incorrectly?
John
Just call T0202 or T0303 etc.
Jr914
Post by Jr914 »
Thanks for the reply I will try it tomorrow. I thinks that should fix because I was using t202 etc. thanks again.
John
Jr914
Post by Jr914 »
I tried the tool change on MDI T0101 ETC. with no movement of the turret. I reloaded the program and all the files from the zip but still the same problem no movement from the turret only in the turret index on the VCP. At this point I have ran out of ideas.
JOHN
(569.35 KiB) Downloaded 110 times
Jr914 wrote: Fri Aug 07, 2020 5:29 pm I tried the tool change on MDI T0101 ETC. with no movement of the turret. I reloaded the program and all the files from the zip but still the same problem no movement from the turret only in the turret index on the VCP. At this point I have ran out of ideas.
JOHN
Can you use the VCP button to INDEX TURRET to move it?
How are you controlling the output required for forward and reversing the turret at different voltages?
Did you follow the attached schematic?
S14988-ACORN_rev4_TIME_BASED_TURRET_WITH_HOME_SENSOR.pdf
(167.72 KiB) Downloaded 101 times
