Hello All,
Will an Acorn work with the Sherline Chucker's Optical Encoder?
Regards,
Art
Sherline encoder
Sherline encoder
Re: Sherline encoder
Manufacturer/part number for the encoder and we can give you some help. If it's an RS422 differential quadrature encoder of at least 1000 lines, it should work fine.
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
As Tom mentioned, it must be a standard line driver differential encoder to be compatible with Acorn.
They can be fairly inexpensive. Need information on your encoder, make/model number/cut sheet. PIcture of it on your machine would be helpful and how it is interfaced with the lathe spindle.
Doesn't Franco have a Sherline chucker/Acorn lathe. He could tell you what he did.
Milton in Collierville, TN
