rotary PP
rotary PP
I am trying to find a rotary PP for vectric vcarve. I found a Y to A that works but I need a X to B. The A one I found does make my rotary turn but the B won't. I was wondering if anyone here has one for their machine. After 2 years I am finally trying to get the 4th axis hooked up and give it a try. I seem to have everything working now just need the PP to try it out.
Re: rotary PP
Try this one. As always, test a new postP aircut to verify proper operation. Remove the ".TXT" after downlaod
Re: rotary PP
Thanks I will give it a try
Re: rotary PP
I loaded it and just letting the machine cut air right now but it seems to be running properly but really slow. The view in CNC12 just shows a thin vertical line and the trail just barely moves up and down it. How do I change the view to show a cylinder and the trail follow around the cylinder or is that possible? Still wanting to test it before I get brave enough to put a bit in the spindle and wood in the rotary axis.
Are there any settings in the parameters that I should be looking at changing to add the rotary axis on the machine?
Re: rotary PP
Bobby...
Not sure that anything will change on the graphing screen...verify proper cutting appearance in CAD/CAM.
I think Parameter 3 should be set to 8, but verify this as its been a couple years since I did one.
What are your Max, Fast, Slow speeds set at for the rotary axis? Know that on a 2" diameter blank surface equivalent to 120 ipm would be ~4600 deg/min
Here is an inverse time mode post that once your axis speeds are proper may help. Same careful use disclaimer. AIRCUT!
Marty has posted a link to Rotary Setup Info here: viewtopic.php?f=60&t=4423&start=10
Re: rotary PP
Ok I see in the notes on the PP, Rotary Feedrate is Slaved to XY if Parm #2 is set to 8". As far as my settings, I wasn't sure what to set them at as I read that they are actually set in degrees per minute not IPM. I just put in some numbers right now to be honest until I learn more. Max is 6000, gast 3000 and slow 360. I'm still trying to learn and the rotary is a totally new thing for me that is why I have just now tried to set it up after if setting on the floor for almost 2 years. The graphing screen is ok if that is the view that it should be on. I just figured that there was a setting somewhere that I did not know about to change it.
I appreciate you taking the time to respond and help.
Re: rotary PP
bmilam wrote: ↑Mon May 25, 2020 12:42 pm Ok I see in the notes on the PP, Rotary Feedrate is Slaved to XY if Parm #2 is set to 8". As far as my settings, I wasn't sure what to set them at as I read that they are actually set in degrees per minute not IPM. I just put in some numbers right now to be honest until I learn more. Max is 6000, fast is 3000 and slow is 360. I'm still trying to learn and the rotary is a totally new thing for me that is why I have just now tried to set it up after if setting on the floor for almost 2 years. The graphing screen is ok if that is the view that it should be on. I just figured that there was a setting somewhere that I did not know about to change it.
Re: rotary PP
For a rotary axis, a Max Rate of 400 degrees/minute is very slow.
Your achievable Max Rate of course depends on your servo motor and your reduction ratio, but a typical max rate on a rotary table with 90:1 reduction might be 6000 degrees/minute. That would be 1500 RPM at the servo motor.
I usually set Slow Jog at 360 (1 RPM) and Fast Jog at 3600 (10 RPM).
Re: rotary PP
I had the wrong numbers listed and updated with the new numbers in my post. I have it set at the moment at 3000/ 360. I have done some research on the stepper it is a Chinese motor by ACT and it is 1.8 degree 2 amp 850ozin into a worm gear reducer size 50, ration 20.
That is giving me 8.5 rotations a minute. Maybe it just appeared slow to me
Re: rotary PP
Gary are you sure about that? With my math a diameter of 2" has a circumference of 2" x pi = 6.28"Gary Campbell wrote: ↑Mon May 25, 2020 9:51 am ... Know that on a 2" diameter blank surface equivalent to 120 ipm would be ~4600 deg/min
To get to 120ipm, the axis needs to turn 120/6.28 = 19 times. 19 x 360 degrees = 6'840 deg/min
Is there something wrong with my math?
-swissi
