Hi all, I have come to the wiring the drive alarm and cannot find on the schematics how to wire them up when the drives (HSS86) are factory set to NO. I have no internet in the workshop and don't really want to mess with the drives anyway. Am I right in thinking I can wire all 3 ALM- to common and then have to use separate inputs for each ALM+ on the Acorn board and set in the wizard which input is which and to NO?
Thanks in advance.
Paul
Wiring drive alarm
Wiring drive alarm
Re: Wiring drive alarm
If they are normally open, all three ALM- to COM and All three ALM+ to input 5Orville wrote: ↑Thu May 07, 2020 5:37 am Hi all, I have come to the wiring the drive alarm and cannot find on the schematics how to wire them up when the drives (HSS86) are factory set to NO. I have no internet in the workshop and don't really want to mess with the drives anyway. Am I right in thinking I can wire all 3 ALM- to common and then have to use separate inputs for each ALM+ on the Acorn board and set in the wizard which input is which and to NO?
Thanks in advance.
Paul
Any drive faults it will cause a Drive Fault
Thanks Marty.
