**RESOLVED** CNC10 to MPU11 on Linux
Posted: Tue Aug 16, 2011 6:17 am
by Maint_1
I've completed the hardware swap which included a change from Compact Flash drive to solid state hard drive. When I boot the PC it loads the CNC application but does not find the MPU11 giving the MPU not responding message. I'm assuming there is some network configuration that needs to be done. How is this handled in Linux?
Also how do I import my PLC programs from CNC10 to the MPU11 platform? Is there a simple method or do I need to recreate them?
Re: CNC10 to MPU11 on Linux
Posted: Tue Aug 16, 2011 8:25 am
by Maint_1
I've checked my network configuration. I only have the onboard NIC and it is set via Ifconfig to 10.168.41.1 and the MPU11 to 10.168.41.2. I am able to ping both and have confirmed that I'm pinging the MPU11 by pulling the ethernet cable to ensure it's the right device. I'm still getting Timeout:MPU11 not responding.
Posted: Tue Aug 16, 2011 9:44 am
by CNC-Global
first of all cnc10 do not support mpu11 .You need to install cnc11 under windows7 or in linux but centoid stop updated after v3.03 in linux so you have only windows option now.
Mpu11 plc is totaly different from cnc10. Old plc do not work in cnc11. Which drive u use with mpu11? Dc3iob ?
Posted: Tue Aug 16, 2011 10:07 am
by Maint_1
Compact flash drive was replaced with new solid state hard drive containing the correct software.
DC3IOB and a DC1.
Posted: Wed Aug 17, 2011 3:22 am
by CNC-Global
Please email at
tech@ajaxcnc.com regarding your problem and new SSD purchase
Posted: Wed Aug 17, 2011 8:46 am
by Maint_1
Linux firewall was turned on. Works now. Ajax converted my PLC programs for me as well.
