G code to fix Quick Change Tool Post not accurate
Posted: Tue Mar 10, 2020 6:18 pm
by davidmunson
I have a mini lathe and have all the tools set up. The problem in that when I run the intercon program, I realized that the tool post is not accurate to relocate the tool properly.
Is there a way to add G code to move the post to a 0 0 position so when I put the tool on I can see it is in the right position?
I tried adding the Gcode with intercon but would not respond to my position and test the position.
I'm Lost.............. Help
Re: G code to fix Quick Change Tool Post not accurate
Posted: Tue Mar 10, 2020 7:05 pm
by Dave_C
I'd say set your G28 to move the tool post to the position that you want for a tool change.
You can also edit the G-code in a text editor and see if G28 is called, if it is not, it is easy to add the call.
Dave C.
