Lathe SolidCam Post Processor for Acorn.
avangard
Post by avangard »
Hi
Here's a lathe post processor for SolidCam. It is based on the standard Fanuc 0t.
I made some changes to Fanuc 0t original post processor.
If someone can make useful changes to the post processor, please post the changes here.
My knowledge was enough only for what I posted.
Sorry for my English. But I want to be useful in this forum.
Lathe_PP_Acorn.rar
Post Processor
(6.27 KiB) Downloaded 190 times
avangard
Re: Lathe SolidCam Post Processor for Acorn.
Post by avangard »
Hi
Made corrections in the post processor. The threading cycle now works correctly.
03062020_threding.zip
threding
(6.61 KiB) Downloaded 139 times
Is that post for SolidCAM https://solidcam.com or SolidWorks CAM? I have lathe and 4-axis mill posts for SolidCAM if anyone is interested.
avangard
Post by avangard »
This is a lathe post processor for Solid Cam ( https://solidcam.com/ ) .
You can post your postprocessor here. It is interesting to compare yours and mine.
Here are my SolidCAM post processors for Mill/Turn (Lathe) and 4-Axis Milling.
SolidCAM_Centroid_GPP.zip
(33.12 KiB) Downloaded 214 times
cscristian
Post by cscristian »
tblough wrote: Mon Mar 09, 2020 2:04 pm Here are my SolidCAM post processors for Mill/Turn (Lathe) and 4-Axis Milling.
Hello.Thank you for sharing.
Can you please attach the Machine ID file that you use with this post processor?there is a file with extension .vmid
Thank you
Here you go. They are not full machine definitions suitable for machine simulation - only enough to specify the minimum machine information for my particular machines.
gMill_4x_Centroid.vmid.txt
(22.92 KiB) Downloaded 163 times
gTurn_Centroid.vmid.txt
(44.03 KiB) Downloaded 150 times
cscristian
tblough wrote: Thu Jan 28, 2021 10:43 am Here you go. They are not full machine definitions suitable for machine simulation - only enough to specify the minimum machine information for my particular machines.
Thank you.i will give a try.
cscristian
Hello.i have try to use this postprocessor but i get some error.do you know what is wrong or where to look?Thank you
Here's the all the post processor files for my mill and lathe. This includes the post processor (.gpp), the pre-processor (.prp), and the machine definition files (.vmid). looks like iNumber_of_Fixtures is defined in the pre-processor file.
SolidCam Centroid Postprocessors.zip
(43.98 KiB) Downloaded 141 times
