Page 1 of 2
Dc310 Lathe on Single phase
Posted: Sun Feb 09, 2020 2:25 am
by mikebramel
Hello, can anyone offer advise if this is suitable for single phase 230v operation?
I believe the VFD will have to be replaced for one rated for single phase input.
Thank you
Re: Dc310 Lathe on Single phase
Posted: Sun Feb 09, 2020 2:29 am
by mikebramel
Few pictures
Posted: Sun Feb 09, 2020 9:00 am
by tblough
You don't give the spindle horsepower, but judging from the VFD it's probably around 10Hp. If that's the case, you probably will not be able to run it on single phase. The largest VFD with single phase input that I know of is 5Hp.
There are postings around the Internet that say you can just use the next larger 3 phase inverter, or one with double the Hp rating (depending on the post), and just use those on single phase. Haven't done it -probably won't try it.
Posted: Sun Feb 09, 2020 11:59 am
by converterking
Posted: Mon Feb 10, 2020 4:21 pm
mikebramel wrote: Sun Feb 09, 2020 2:25 am Hello, can anyone offer advise if this is suitable for single phase 230v operation?
Thank you
The control as a general rule may run single phase.
You would likely have to change the VFD.
Posted: Mon Feb 10, 2020 5:25 pm
From Centroid Support staff based on the Control Number provided:
"That control was wired in Taiwan.
It should have been wired 220V single phase for the control.
The flood and inverter / spindle would need 3 phase."
Posted: Mon Feb 10, 2020 8:56 pm
by mikebramel
Thank you
X and Z are moving and spindle can be jogged on single phase. Havent figured the turret out yet. Im not sure if I can feed that motor with a small static phase converter, that would be easy to implement
Posted: Mon Feb 10, 2020 8:59 pm
Use a small VFD for the turret. You can control forward and reverse with it.
Posted: Mon Feb 10, 2020 9:07 pm
by mikebramel
Yes, a good option, but I was hoping to run it this week LOL
Posted: Mon Feb 10, 2020 9:08 pm
Patience is a virtue...🤪
