COM wire connections
wagdamotta
Post by wagdamotta »
Hi Marty
I watched a video yesterday from you at YOUTUBE and I saw you make the connections from the power supply to the Acorn and to the E stop switch and for the power supply for the servo drive, and you connected all COM together and used a block, I have problem before with my cnc control that when I turn the power off the servo jump the position, I don't know If you remember, I send to you a video before on YOUTUBE.
But after I watched your video I when take look my connections and I saw that I not connect all the COM together like you did, from the COM of Acorn power supply you put a jump wire to the drive power supply and to the connection block.
Do you think because I not did the same may cause the problem? If yes let me know please and I change the wires because I put a switch between the power supply and the driver for me turn the power off the drive before turn the power off on Acorn board.
Thank you
Wagner Damotta
Re: COM wire connections
Wagner,
post a photo of your setup, what kind of motors and drives are you using, link to the manual? etc..
post a fresh report.zip.. follow the posting guidelines here..so we can help you. viewtopic.php?f=60&t=1043
and in general follow the Acorn hookup schematics https://www.centroidcnc.com/centroid_di ... matics.zip
wagdamotta wrote: Sat Feb 08, 2020 6:19 pm Hi Marty
Thank you
Wagner Damotta
Wagner,
I vaguely remember. As Keith said, please post the information requested.
I tie my power supply commons together.
wagdamotta
hi
I have DMM DYN2 servos.
report_38D2693D7A14-0118180556_2020-02-11_17-15-42.zip
Thank you
wagdamotta
Hi
I have the DMM - DYN2 servos
Thank you
Wagner
(334.43 KiB) Downloaded 153 times
Wagner, did you ever consult with DMM about this problem?
I believe they were aware of the lurch but may have corrected it with a firmware update. But I only experience this on power up not power down.
Mkelcy
Post by Mkelcy »
FWIW, I've had good luck contacting DMM by email at: info@dmm-tech.com
Generally I've gotten a response in less than 24 hours, including over weekends.
