Acorn Wizard Not Loading -- Now with Windows 10 -- <resolved-- Fixed w/ 4.20.1 old CPU support added>
Hello,
When I upgraded to 4.2 I encountered this problem after reloading the report.zip file as instructed for an upgrade. So, I just re-installed the software and added everything manually. Things seemed to work fine until today. (Maybe I couldn't get back into the wizard before but didn't know it.) Anyhow, today I couldn't load the wizard again. So, I tried loading my original report.zip file after I installed the software and could get back into the wizard. After configuring the Acorn for my lathe (again) I now can't get back into the wizard.
A screenshot of the error message is attached as well as the report.zip file. Re-installing the software works....until I configure Acorn for my lathe. Any ideas?
Thanks!
download/file.php?mode=view&id=9459
download/file.php?mode=view&id=9460
Thanks!
- report_780473848BC1-0205191617_2020-01-14_09-57-31.zip
- (328.81 KiB) Downloaded 149 times
Re: Acorn Wizard Not Loading
thanks for posting the report.zip.. the report says the CNCPC is running on Windows 7 Ultimate. which is not supported. Use Windows 10.
please review the CNCPC requirements AND the Window 10 setup procedure for CNCPC use here..
https://www.centroidcnc.com/centroid_di ... guide.html
Re: Acorn Wizard Not Loading -- Now with Windows 10 -- Same problem
Hello,
I "upgraded" to Windows 10. Same problem. New report.zip file attached. Thanks!
Brenden
Brenden
- report_780473848BC1-0205191617_2020-01-14_17-42-51.zip
- (346.06 KiB) Downloaded 86 times
How are you starting the Wizard? The Wizard is now launched from within CNC12.
From a fresh CNC12 startup,
From the main screen with NO job running
Press F7 Utility
Press F10 Acorn Wizard
I noted three icons in your task bar in the screen shot you posted...and I see the Wizard splash screen but you are not in the Utility menue (F7)
Press F7 Utility
Hello,
That's the way I've always loaded the wizard. I just tried it again and all I did was to run CNC12, press F7, press F10. Same error. I did not even home the machine.
Thanks!
Thanks!
martyscncgarage wrote: ↑Wed Jan 15, 2020 9:05 am How are you starting the Wizard? The Wizard is now launched from within CNC12.
Press F7 Utility
what are the windows 10 language and regions settings set to?
Hello,
The language is English and region settings are United States.
Thanks!
Thanks!
did you try to run as administrator?
do you have internet connection to the PC with the issue?
Windows 10 Enterprise Account not set to administrator.
posts covering this subject.
viewtopic.php?f=63&t=2930&hilit=wizard+start#p21461
Follow the Windows 10 for CNC PC Setup instructions.
Hello,
I double-checked and my account is part of the administrators group and running the software using Run as Admin makes no difference. I also found some files were set as read-only and unchecked the box on those files. There was no change and the wizard still doesn't run.
Thanks!
Thanks!
