Spindle hour meter (Resolved)
- CNC Control System Serial Number: 4031
Re: Spindle hour meter
OK, thanks Marty.
Look at the top of a recent report*.txt file.
CNC12 does track this information. There just isn't a well-established interface to it yet.
I believe the data is in the file mt.stats, which is included in the urf.zip file in a Report. That is a binary file, so it will take a little experimenting to decipher.
Machine Timers info
Power On : 000037.931
Job in Progress : 000002.421
Spindle Running : 000000.480
Since : 11/08/2020
Thanks Marc! I have overlooked that information. Always a pleasure having your YEARS of expertise here!cncsnw wrote: ↑Wed Feb 24, 2021 4:11 pm Look at the top of a recent report*.txt file.CNC12 does track this information. There just isn't a well-established interface to it yet.Code: Select all
Machine Timers info ---------------------------- Power On : 000037.931 Job in Progress : 000002.421 Spindle Running : 000000.480 Since : 11/08/2020
So, if you are employed, can you do something with that information as the poster requests?
It would be a little convoluted, but one could write a freestanding program that runs from a command prompt or batch file, to read the mt.stats data and write the results into a CNC macro that sets user variables equal to each value.
A CNC program or macro could then call that application using M130; wait for it to do its work; then call the resulting macro to retrieve the variable values; then do whatever it wants (e.g. with an M225 prompt).
It would probably take me three or four hours to make it work.
If all I have to do is run a report once in a while I'm OK with that. I'll try running a report today and take a look at it.
