[media][/media]Plasma/ Engraver 36x36 up and running. It sitting up on Saw horses so i could paint underneath. Acorn did not like turning on and off 100 Amp Thermal dynamics plasma from the Acorn relay board it would fault out the Acorn board but using the Acorn relay to operate secondary relay it worked great. I am rechecking all grounds and installing a grounding rod at the machines new home.
Used Fusion 360 to create the part file and generate the NC file for Acorn
Video to follow:
Acorn Plasma/Engraver first run
Re: Acorn Plasma/Engraver first run
cool, thanks for posting..
quencharcs would be good idea.
