motor tunning
Posted: Mon Jun 13, 2011 9:56 pm
by pablocnc
Please, I need that you help me with the last to finished the connections, my machine is connecting in this moment, buy i have a problem, I don`t now the form of tunning my motors, because my motors jump a lot when i turn off from keyboard.
I have a cuestion, i have installed win7 version in spanish, you belive that i have change the system by win7 version english?
were often slow in getting plc ok, this shows a problem?
thank you
Re: motor tunning
Posted: Tue Jun 14, 2011 2:29 am
by CNC-Global
For the CNC11 software following is the procedure for Language and Auto tuning
For the Language Please go in to the F1(setup)---->F3(config)---->F3(Parms)
set parameter 7 to 2 (for spanish Language) as in the picture
Now for the Auto Tune Please go in to the F1(setup)---->F3(config)---->F4(PID)----->F5(Tune)
After F5 Key Pressed you see the Screen
Press cycle start or ALt+S key to run the Atuo tune procedure
That procedure will autotune all three axis
Auto tune automatically calculate Ka ,kv kg ,acceleration and Max velocity of each axis
I hope this will help you
Re: motor tunning
Posted: Tue Jun 14, 2011 7:42 pm
by pablocnc
Thanks for you response, but, i forgot to write that my software is mach3, :oops: , please, if you can help me with the tunning my motors but to mach3 system..
I am sorry...
Re: motor tunning
Posted: Thu Jun 16, 2011 8:50 pm
by pablocnc
pablocnc wrote:Thanks for you response, but, i forgot to write that my software is mach3, :oops: , please, if you can help me with the tunning my motors but to mach3 system..
I need the information, please, if some people have the configuration, please help me
I am sorry...
