Acorn ClearPath DIY Control for AVID & ShopBot
Gary Campbell
Post by Gary Campbell »
For those looking to build an Acorn with Teknic ClearPath control system. Save the time sourcing high quality parts and the costs of wrong parts and wiring mistakes by taking advantage of this new REZurrection Control product; the Acorn ClearPath.
Features:
Upsized (24x20,8) Steel control Box
Upsized 60W 24V power supply
CNC Drilled and tapped for accuracy
16ga Steel backplane
Up to 60 Amp capable power block, designed to expand
Circuit Breaker Protection for all devices
Accommodates routers or spindles (up to 2) (1 included)
Accommodates Teknic IPC-5 Power Supply (1 or 2) (NOT included) Prewired
IPC-5 Heat Sink Mounting bracket (1 standard)
Acorn 8 CH Relay on Din Rail
4 CH Servo Alarm Relay
Spindle Logic Harness (10Ft)
Spindle Speed Harness (10Ft)
Servo Control Connection Block (prewired & labeled)
Servo Power Connection Block (prewired & labeled)
Cord Grommets for cable entry
Load Break Power Switch
Wire Duct.
Prewired and tested with included Lenovo CNC-PC
$2495 including setup & CNC-PC, Acorn Pro software
$2895 adds C86ACCP & expanded IO terminals
GCnC411@gmail.com for more info
Last edited by Gary Campbell on Mon Apr 18, 2022 10:28 am, edited 2 times in total.
Gary Campbell
Re: Acorn ClearPath DIY Control Box
For those that need them, I also offer Planetary gearboxes and SB PRT & PRS adapter plates that adapt modern gearboxes to SB Frames. Gearboxes & motors are drilled and/or tapped to mate up with each other and the adapters for a small fee.
PRS NEMA 34 adapters and gearboxes are shown below.
PRS NEMA 23/34 adapter: $75
PRT NEMA 23/34 Adapter: $100
PRS Buddy X Axis Adapter: $150
pretty!
Gary Campbell
A couple shots showing the PRT model adapter plates
erer44
CNC Control System Serial Number: 78047348f8f5-0606192079
Post by erer44 »
How is the end-play on those gearboxes? Have some helical rack and pinion I'd like to find a use for...
Gary Campbell
Initial testing/measurement showed good, but don't have any daily commercial use customers with helical rack to verify end play over time.
JamesMacc
Post by JamesMacc »
Very interested, Gary. Emailed. Building a custom 1500mmx3000mm router, and need this badly.
Gary Campbell
We will be in contact this week
hivoltage
Post by hivoltage »
Where did you get the box?
I need one for my setup.
Gary Campbell
Depending on the size, Automation Direct or other online sources
