DMM Technology - Coolant splash proof Servo cables
CarlEnglish
CNC Control System Serial Number: Serial Number
Post by CarlEnglish »
Hi, All
Thought i'd share this low cost tip i found for splash proofing cables, while searching for cable conduit today.
I realised a Standard 3/4" garden hose tap fitting works.
Just remove the inner brass from the Hose Fitting, Remove the DMM white plastic insert and rubber grommet.
Install the hose fitting and reinstall the DMM Clamp Fitting without the two clamps and two screws, maybe add a little sealent to be sure, some Black hose and it will look great.
This tip applies to the DMM Technology AC Servos, models 1.0Kw, 1.3Kw, 1,8Kw.
And maybe others out there as well.
Carl
