DMM DYN4 Setup with Acorn
If you are using DYN4 with Acorn, software revisions up to 4.18, you MUST go into the ADVANCED tab in the Wizard and check the boxes in front of ENABLE.
Reason being, is that DYN2 uses the DB25 for its signals and the DYN4 uses the header terminals on Acorn for its Axis signals. The ENABLE signals are OPPOSITE each other. So until Centroid separates the two, and gives them their own Radio button, you have to invert the ENABLE signal for DYN4 manually in the Advanced tab.
