I was testing and moving the machine this weekend, and found a bit of strangeness. w/ my mpg.
it has only happened twice but is concerning.
I was jogging in Y then set the mpg to z and spun the wheel the machine moved in y about an inch then move in z.
has any one seen this? It is like the machine did not see the change in axis, then it did.
Jerry
MPG strangeness
- CNC Control System Serial Number: 985dadec3fe0-0423180848
MPG strangeness
Re: MPG strangeness
jerry, looking into the CNC support crystal ball...
i suspect you are changing the axis selector knob position before the machine has completed the move that it is currently executing and (or while you continue to spin the MPG wheel). said another way...if you flip the axis selector knob before the machine has completed the current move.. it will finish the move it is on..and then change axis selection to match the knob.
this normal action is exacerbated with long accell times and or other combinations of settings, so without a fresh report.zip i can't see what settings you have.
Re: MPG strangeness
thanks
- report_985DADEC3FE0-0423180848_2019-06-10_09-10-01.zip
- (320.84 KiB) Downloaded 88 times
