Notepad ++ Compile Error
burke_wl
CNC Control System Serial Number: 0506190790
Post by burke_wl »
I'm getting the error below while trying to compile the PLC source code. I followed the tech bulletin 294 to configure Notepad++ and I believe I have my folder structure correct for saving files. I was able to get the PLC source code to compile via the windows command prompt. Anyone familiar with this error?
"C:\cnct\compile.cmd" "Centroid-Lathe-Standard-OAK-r2-Axis-Brake-setup2.src"
; about to start a child process: ""C:\cnct\compile.cmd" "Centroid-Lathe-Standard-OAK-r2-Axis-Brake-setup2.src""
CreateProcess() failed with error code 2:
The system cannot find the file specified.
================ READY ================
Re: Notepad ++ Compile Error
try compiling without using Notepad ++ and see what happens..
here is link to PLC programming how to video playlist for your reference. the first one goes over setting up Notepad ++
https://www.youtube.com/playlist?list=P ... i2WKIedQlQ
Well, it states that it cannot find "compile.cmd" in the cnct directory. Perhaps you were trying to run mpucomp.exe?
burke_wl
Post by burke_wl »
cnckeith wrote: Thu May 30, 2019 9:06 pm try compiling without using Notepad ++ and see what happens..
I was able to get the source code file to compile using the windows command prompt.
burke_wl
Post by burke_wl »
tblough wrote: Thu May 30, 2019 9:07 pm Well, it states that it cannot find "compile.cmd" in the cnct directory. Perhaps you were trying to run mpucomp.exe?
Here are a few screenshots that show the file locations and names. Also a screenshot of the Compile Execute command from Notepad++ which was copied and pasted from tech bulletin 294.
compile.cmd text.PNG (4 KiB) Viewed 3100 times
Compile Execute.PNG (11.71 KiB) Viewed 3100 times
Rename "compile.cmd" to "compile.bat" and update the execute command to reflect that as well.
burke_wl
Post by burke_wl »
tblough wrote: Fri May 31, 2019 10:55 pm Rename "compile.cmd" to "compile.bat" and update the execute command to reflect that as well.
Hi Tom,
I tried to relabel the compile.cmd file to compile.bat and updated the execute command and got the same error as before.
Wes
Then the only other thing is that compile.bat is not in CURRENT_DIRECTORY.
