Generating random numbers during program execution...??
doug98105
Post by doug98105 »
The Centroid macro language doesn't include a random number function.
Is there a way to generate random numbers during program execution using existing macro functions ? Why???, because I'm doing a project where I want to drill a random pattern of holes with each run of the program giving a different hole pattern.
I can do this in CAD/CAM, but it's cumbersome because of having to create a separate program for each program run. In other words if I want, for instance, 50 random hole pattern parts I'd have to create 50 separate programs.
Re: Generating random numbers during program execution...??
Based on Wikipedia:
#100 = (1103515245 * #25012 + 12345) % (2^31);
Parameter #25012 is the time in seconds from CNC12 as a seed
eng199
Post by eng199 »
The system variables should allow you to put something together. #25011 or #25012 times could work in some cases, or could be a seed for a pseudorandom calculation you can find online.
If your machine has a spindle encoder, it should be a good random number in most cases, if you are machining between calculations. Spindle encoder should be somewhere in #5021 - #5028, depending on mapping.
doug98105
Post by doug98105 »
Thanks for the replies. Using #25012 seems to do the trick. I'll do some testing the next few days to verify.
My machine doesn't have a spindle encoder so that method is out.
