Step motor from Axis Z move only UP
cncprimoserv
CNC Control System Serial Number: 7804732c32be-0130191578
Post by cncprimoserv »
First time posting around here.
We're building a router machine that's use a Acorn board + leadshine driver (NEO-LS-ES-D1208) + huanyang inverter with a 2.2 kw water cooled spindle.
Hookup everything as the schematcics #S14941.DWG for the step motors.
After all conections, i've made a wire-by-wire checkup and was everything fine.
all the axis works perfect.
but the problem is with the Z axis. that moves only on the Z+ direction. So i cant put down when joging.
Any sugestions ? maybe a configuration on the wizard or wrong wiring, step motors drive configuration ?
Thanks.
S14941-ACORN_rev3_MULTIPLE_LEADSHINE_CS-D1008.pdf
(118.35 KiB) Downloaded 139 times
Re: Step motor from Axis Z move only UP
cncprimoserv wrote: Fri Mar 29, 2019 3:39 pm First time posting around here.
Thanks.
Please post a report and screen shots of your Wizard screens. Use WINDOWS 10 Snipping tool to grab the screenshots
Gary Campbell
Post by Gary Campbell »
What is the step pulse setting?
Gary Campbell wrote: Mon Apr 01, 2019 10:35 am What is the step pulse setting?
You are so nice Gary....
Folks need to post a report along with screen shots of their Wizard pages.
No info, not much help.....
Gary Campbell
I stand corrected Marty! :D
No info, no answers
We aren't trying to not be helpful, but we can't "SEE" what you see.
We are starting to take the stand that if users don't follow this post:
viewtopic.php?f=60&t=1043
You won't find much response from us.
It takes CONSIDERABLE TIME and EFFORT to try and stay on top of all these requests.
Please be considerate and post the information asked of you, including any links to manuals of:
Axis Drives
Axis Motors
VFD's etc.
Gary Campbell
Axis Drives
Axis Motors
VFD's etc.
Roger that.
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
You might want to check you input ports in particular port 5, make sure you don't have the touchoff input configured incorrectly. This is exactly how it behaves if it is configured wrong it will not let you go Z negative, to protect the probe.
Russ
Dave_C
Post by Dave_C »
I've seen this stepper issue before when it will only go one way!
There is a switch on the driver for bi-directional control. It comes set to go one way no mater what the direction is. I have no idea why they do this but I've seen it before on some models of steppers.
Check your manual for the dip switch settings.
Dave C.
grassyfork
CNC Control System Serial Number: 78047384922D-0306191723
Post by grassyfork »
I had a similar problem with Z , own mine max limit was wrong
