No analog voltage 0-10 volts
wetpaint43
Post by wetpaint43 »
No analog voltage out. Watched Martys video. Also I'm trying to use a Huanyang inverter GT 2.2 series. I can not find a schematic that matches the input labels that I have on my vfd. Please excuse my lack of knowlage I'm new at this computer stuff.
report_40BD32E92A90-0803181114_2019-02-06_14-10-09.zip
(198.83 KiB) Downloaded 104 times
Gary Campbell
Re: No analog voltage 0-10 volts
Post by Gary Campbell »
Connect to AI1 (analog in 1) and COM (analog common)
Not saying this is the case, but be aware of Huan Yang VFD knock offs. Yes, the chinese knock off their own products.
If I buy Huan Yang VFDs, it is from the Amazon Seller Huan Yang Electric, no one else.
wetpaint43
Marty I got the vfd to work with acorn but I still have no analog voltage out. I was hoping for a secret switch that I missed but it doesn't look good does it :?:
Did you watch and test per my video?
https://youtu.be/5B1EaeKjT9w
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
Wetpaint43,
Are you saying you get no analog voltage out of Acorn? If you want the VFD to accept the Analog voltage you have to also change the speed input parameter on the VFD. By default the parameter is normally set to operate from the operator panel of the VFD.
Russ
wetpaint43
Russ, When I put my voltage meter on the Acorn 0-10 volt analog out while running a program I get no voltage. Marty, I did watch your video after noticing I had no voltage out. I took all the wires off of acorn as you instructed and ran the series of test. Today I wired up a pot and everything worked as it should just no control for spindle speed from acorn. Thanks for looking into this though.
Billy
Gary Campbell
Post a screen shot of your spindle Wizard screen. What rpm was set in the software for the test?
wetpaint43
I'll post a picture tomorrow, the rpm was set at 1000 max and 0 min.
Gary Campbell
Type in M3 S1000 press cycle start and measure voltage
