We came up with these 3D printed DC servo motor encoder caps for the case when upgrading a DC servo to a modern encoder the existing motor end cap is too small. both the .stl 3d print ready file and solid model Rhino file is contained in the link below (solid model is included in case you want to modify the design to suit your particular needs). here is the download link to zip file containing both the .stl and the .3dm files (special thanks to Mike W on the is project) http://www.centroidcnc.com/centroid_diy ... r_cap.zip
The 3D print cap design accepts the Centroid DC motor cable strain relief kit found on the Allin1DC webpage.
http://www.centroidcnc.com/centroid_diy ... oller.html
more info on DC servo motor encoder retrofits found here. http://www.centroidcnc.com/sem_dc_servo ... rofit.html
3D printed DC servo motor encoder caps, Encoder upgrade.
