What is the proper format for writing an M201 command?
Ex: N100 M201 "move clamp"
OR
N100 M201 move clamp
M201 seems to be used differently in different systems and I cannot find an example of how the prompt message is entered for Centroid.
M201 command format
M201 command format
Re: M201 command format
M200 example from Chapter 13 of the Operator manual...
M200 "#)1. Jog the X axis to the desired X0 position\n2. Jog the Z axis to the
desired Z0 position.\n3. Press Cycle Start to continue."
http://www.centroidcnc.com/centroid_diy ... -v4.12.pdf
other similar examples of formatted string commands can be found in this macro.
- mfunc6 (1).mac
- (11.43 KiB) Downloaded 93 times
