Centroid Wireless MPG
rickwjenn
CNC Control System Serial Number: 38D26975C27C-0621181008
Post by rickwjenn »
Got the Centroid Wireless MPG for the Acorn and highly recommended it. Install was very easy with only issue the need to reboot Windows 10 as it was unidirectional communication only until reboot. Highly recommend this tool.
The 1X jog is great for finding edges and part zero. It was a really challenge from the PC with a mouse....
Used the MPG right way to align my vise with x axis and find/fix a bit of sag in the head that was showing up on parallel fact cuts.
https://www.youtube.com/watch?v=xgOGCGUTKZ8
While I am learning Fusion 360, I wrote a simple G code program, loaded it in CNC 12, used the MPG to set Part Zero and started a test piece for a steering actuator clamp (2.5" diameter) I am going to make for my dad's 58 Chevy truck street rod.
https://www.youtube.com/watch?v=7Io4cw2qHAE
Re: Centroid Wireless MPG
thanks for posting the videos! looks great.. give us an overview on your machine , make model, specs and the control configuration, motors , drivers etc..
ScotY
Post by ScotY »
The MPG is invaluable and money well spent! The one thing I wish it could do is jog at an adjustable but steady rate. For quick manual work, like facing a piece of stock, you need to crank the dial. The smoother you can do that, the nicer the finish. Not sure if there’s any way to make this happen?
Gary Campbell
Post by Gary Campbell »
The Feed + and- buttons will do just that
ScotY
Post by ScotY »
Gary Campbell wrote: Sun Aug 26, 2018 7:49 am The Feed + and- buttons will do just that
Really? :lol: You mean all this time I’ve been doing it the hard way? How do you adjust the feed rate? Will this just be your set fast/slow jog speeds? I’m not home right now so can’t check myself but I’m dying to know. :lol:
Gary Campbell
Really? You mean all this time I’ve been doing it the hard way? Looks like it! :D
How do you adjust the feed rate? With selector set to feed then use the mpg wheel
Will this just be your set fast/slow jog speeds? For the "+" & "-" keys, whichever is currently active on the VCP
ScotY
Post by ScotY »
Oh, geez...I guess I’m not very observant as my wife often says! :lol: I’ll give that a try soon. Thanks, Gary!
rickwjenn
Post by rickwjenn »
cnckeith wrote: Wed Aug 22, 2018 9:40 pm thanks for posting the videos! looks great.. give us an overview on your machine , make model, specs and the control configuration, motors , drivers etc..
Thanks for all the help here...
The machine is a PM-940CNC
Leadshine Steppers and Drive Controllers
3200 steps/rev
Delta VSD driving 2HP 220 1Phase motor
