Encoder connectors
converterking
Encoder connectors
Post by converterking »
Does anyone have the part # from Digikey or any other electronics supplier for the encoder connectors and pins that Centroid uses on their encoders?
Dave_C
Re: Encoder connectors
Post by Dave_C »
I got mine off of Amazon. It is just a male DB9 connector and I bought the one with the screw terminals so I can remove it easily to thread the cable through holes.
The pin out labels are on every Acorn wiring diagram! (Right in the middle so we do over look it for some reason) :roll:
Dave C.
converterking
I don't mean the db9 connectors but the flat connectors that Centroid uses on their encoders and on the opposite end from the db9 connector on their encoder cables.
Centroid_Tech
Post by Centroid_Tech »
Dave_C
Post by Dave_C »
It would probably help if I read your post a little better! Sorry for the confusion....
Dave C.
