CNC10 Servo3IO spindle not turning on
Posted: Sat Mar 31, 2018 5:55 pm
Ok - a little background - When i bought his machine a few years ago, it had a problem where once in a while the spindle would just shut down mid program. The Direction control output from the Servo3IO board and the analog speed control voltage would just drop out - no errors - the drives would keep running sometimes breaking the cutter before i could hit something to shut it down - feed stop, tool check or E stop. Restarting the program would reset everything and the machine might run for quite a while before doing it again. It got less and less frequent and i thought the problem may have gone away until today. I go to fire up the mill - it seems to take a while to boot up and I see something I have not seen before - a message telling me the guard is open. There are no guards - no limit switches, etc on this machine. I homed fine and I went to set part 0. I usually spin the spindle at a few hundred rpm when touching off the part 0 - I immediately got a Feed Stop red box, the Feed Stop LED lit up and teh spindle would not turn on manually. Finally got that cleared and tried to run a program to see what would happen - as soon as it gets to M03, it tells me to set the spindle to auto - when I do, I get the Feed Stop red box again. So - at this point I'm trying to see what is causing this - the voltages on the outputs tell me that the inverter is not being told to turn on - direction input both at 5 volts and analog output at 0 volts - speed on the screen reads 0. I ran a report - it is attached to this post.
