Moving Gantry CNC Router uses paired AC servos on the gantry axis. Previously run by a Mach3 system the owners upgraded to Acorn CNC controller for faster smoother performance.
The machine is a custom built router that uses Delta AC servos, on all axes. The 4th and 2nd axis are paired and drive the gantry.
The photo is from yesterday, test cutting for the first time, notice CNC12 smoothing feature is on. With the Acorn system the Surfboards are coming out faster and smoother than with the old mach3 setup. Centroid's CNC12 G code smoothing is a key component to the better results by eliminating the faceted cuts that were in the Mach3 produced boards. The Acorn produces a better board while reducing machine time and hand work time while being reliable and eliminating scrap parts and wasted time.
Acorn 14 foot CNC Router Surfboard Shaping Machine
- S14865-ACORN, DELTA ASDA-A2 SERVO DRIVE.pdf
- (65.27 KiB) Downloaded 84 times
- delta_ASDA_setup_for_acorn_use.pdf
- (325.15 KiB) Downloaded 101 times
Re: Acorn 14 foot CNC Router Surfboard Shaping Machine
Quatro posted a video on their facebook page showing the Acorn CNC controller in action.
https://www.facebook.com/quatrowindsurf ... 966524268/
