Acorn coming up with 9031 drive fault even if set to bench test. Any idea's?
Acorn 9031 drive fault New installation (resolved, wire like schematic shows)
- CNC Control System Serial Number: (9884E398B8B31130170293)
Re: Acorn 9031 drive fault New installation
Paul, please read this post:
viewtopic.php?f=20&t=383
Don't take offense, but you are not providing enough information. We are happy to help if you can provide more info.
If you do figure it out before then, please report back with what you found.
Fixed in5 not connected
Ok, see, I thought you were starting Acorn for the first time and running the initial benchtest on it, where you SELECT benchtest radio button in the Wizard, save the configuration and then start CNC12 to ensure connection between the PC and the Acorn board.
Sounds like you have everything wired up and testing on the bench before installing on your machine?
Glad you got it sorted.
