Looking for a wiring schematic for the legacy servo3IO
the1depot
CNC Control System Serial Number: A2001675520
Post by the1depot »
I have a Milling machine with a servo3io. When I purchased the control there was a connection drawing and installation manual. I have looked everywhere and cannot find the documents. The website had these years ago, but they are no longer available for download. Are they available?
Thank You
diycncscott
Re: Looking for a wiring schematic for the legacy servo3IO
Post by diycncscott »
Your serial number/system id invalid. If you could post a report or the correct system id, I will post the correct schematic for you system.
In the meantime, I've attached an ATC schematic that should include most of the information you need (and probably a lot more).
here:
atc3_dc3io.zip
(909.89 KiB) Downloaded 128 times
Centroid_Tech
Post by Centroid_Tech »
Scott accidentally sent you a schematic for a DC3IO not a SERVO3IO. I don't know why he sent you an ATC schematic. Did you inform him that your machine has an ATC? He is correct in that if you can provide us with a current report from the system, we will be able to provide you with the schematic that shipped out of Centroid with that system. Attached is a basic SERVO3IO schematic.
K0100109_M400S_Generic_Inverter_230VAC.pdf
(196.26 KiB) Downloaded 81 times
the1depot
Post by the1depot »
Thank you for the information. This was very helpful to getting the machine back on the air again. All is good now. There is no ATC on this Milling Machine. I have a DC3IO that does have a tool changer. It is working fine. So both drawings are great to have. SYS ID: XJGFHDGIEF (0929040236) SERIAL# A2001675520. This is what is on the Options Screen
Centroid_Tech
The attached schematic shipped out with that system, A50026, which is just the basic wiring schematic. You can use this schematic or the previous one I attached.
SERVO3IO.pdf
(83.52 KiB) Downloaded 105 times
the1depot
Post by the1depot »
Thank You
