Are Dirve Inerface signals Sink or Source?
Posted: Wed Sep 03, 2025 6:01 pm
I'm using the Flying Lead cable #13133 to connect to model MR-J3-A Mitsubishi Servo drives. The Inputs are currently wired for Sinking control.
I need to verify that the OAK's ENABLE (Pin 21, Brown wire) is functioning. What is the Output bit in the parameter display for Centroid's OAK CNC?
If the connection is NOT sinking, I will need to add a relay to invert the control. I am reading the Servomotor encoders perfectly.
I might hard-wire the enables ON, but I'd rather not. When I complete this retrofit, I will release the schematic and parameters for the servo drives and the Yaskawa spindle drive.
