First parts after servo conversion
I have recently changed the steppers on the linear axis to A6 servos. 400W XY and 750W with brake on Z.
Quite overkill on the dirt-cheap benchtop mill, but with AcornSix and full closed loop with scales very precise for the cheap hardware....
ok, AcornSix and my cutting tools are not that cheap :mrgreen:
Less than 0.01mm deviation in the first shot from CAD/CAM to the milled part and this CuSn8 is not easy to cut.
This small sucker is freaking fast now with 10m/min rapids, but still super smooth thanks to the s-curve acceleration from Centroid.
Right now, the mill is making more parts unattended in the basement running on the latest beta software, while I am drinking wine in the living room.
That is what I like most on Centroid 100% reliable performance.
Chaz
Re: First parts after servo conversion
Post by Chaz »
Great stuff. Is that 4th Axis rotary work? If so, how are you doing this is multiaxis in Fusion looks to be locked?
It is only with indexing the A axis and parallel tool path with a ball nose mill.
Chaz
Post by Chaz »
suntravel wrote: Tue Sep 02, 2025 7:39 am It is only with indexing the A axis and parallel tool path with a ball nose mill.
Thanks. So does it then move A automatically in the output GCODE?
Sure it is posting the A codes.
Very easy to do, just use tool orientation in fusion and a PP with 4 or more axis
For 4 Axis the one from swissi is fine, for more use mine, but it will need a machine model, because the kinematics are used from the machine simulation.
Some screenshots how I made the tool path in fusion with simulation.
Chaz
Post by Chaz »
Thanks. I might look at that for my Granite Dental machine. Didnt think it was possible for more than 3 Axis on the normal Fusion license without addon.
