Win 7 vs Win 10
Win 7 vs Win 10
Which Windows version is better for CNC 11 3.16?
Re: Win 7 vs Win 10
CNC 11 is supported under Windows 7, 8, and 10.
CNC 12 is only supported under Windows 10.
If you are building a new PC, it is highly recommended to use Windows 10 so it is future proof.
Re: Win 7 vs Win 10
Like Liviu mentioned, if you plan on upgrading the software, go with Windows 10.
CNC12 isn't supported on any versions prior.
Probably like me, you hate to move up to 10 from rock solid very familiar 7. But I had to push myself in that direction.....
I remember doing the same thing from XP to 7
- CNC Control System Serial Number: (9884E398B8B31130170293)
Re: Win 7 vs Win 10
Does the cnc software run on 64 bit pc. On all the specs I see no mention of 32 or 64 bit
Re: Win 7 vs Win 10
It runs on both 32 bit or 64 bit. If you are building or buying a new PC I would highly recommend going with the 64 bit version (pretty much the universal standard now) for future update capabilities. The 32 bit version can only address 4gb of RAM which is the current minimum requirement.
Re: Win 7 vs Win 10
What about Win 10 Home or Win 10 Pro ?
Would this make any difference ?
Thanks.
Thanks.
Re: Win 7 vs Win 10
Either should work.
Re: Win 7 vs Win 10
One note on Win10 Home. You have no Windows Update options. You must accept them. With Pro you have some flexibility. It is also much harder to totally get rid of the Firewall and Update nag notifications. Other than that.....
Re: Win 7 vs Win 10
Win 10 Pro you can disable defender.
