Intercon question
Moderators: cnckeith, Joey
_Doug
CNC Control System Serial Number: Acorn 9471
Intercon question
Post by _Doug »
Morning,
This maybe my fault as I’m not familiar with the Intercon program.
When opening a new file/drawing in Intercon ….the default hook stays on screen.? I click File> New and I don’t get a blank screen start new drawing.
The hook stays on screen. When I import dxf it installs it over the hook? It did this also before the reinstall of Intercon.
This makes Intercon somewhat of a challenge to use!
Your help would be much appreciated….. Thanks Doug
Joey
Plasma/Laser Lead
Re: Intercon question
Post by Joey »
When creating a file you will need to except the title and programer menu to get a new job.
If you just escape out then intercon will not create a new job.
_Doug
Post by _Doug »
Hi Joey,
Thanks for that info!
Now that I can open a clean drawing the previous problem of not being able to open a DXF file persists! Computer thinks for 30 sec or so then shuts down Intercon and I get the cnc12 screen.
Do you get the same shutdown behavior when using F8 Graph? I'm wondering if this is a graphics driver issue.
_Doug
Post by _Doug »
Hi,
Yes the response is the same on the graph.
It’s a new computer and it so happens it wanted to do a rather long update to the drivers , was hopping for a miracle but not so, the same thing happens. Sometimes I get the almost the full dxf drawing downloaded…as soon as it’s almost finished it shuts down and reverts to the cnc12 screen. Thanks for the info
Doug
In which autocad version is the DXF file saved/exported ?
If your computer has a separate graphics card, you might try a different one. If it's integrated graphics, do you have another computer you can try?
_Doug
Post by _Doug »
Hi,
Computer has integrated graphics card. Will see if I can try a different computer today.
Dxf files were exported in r13.
Thanks for your help ….Doug
Could you pls. try R12?
That version works best in the mill software. Also splines have to be converted into curves or small lines. CNC12 can only read arcs and straight lines.
