Milling ABS (pulse) ring slots in intercon
bbatarelo
Post by bbatarelo »
Hello,
I'd like to mill 60 radial slots on my custom ABS ring. Basically everything is a lathe work except those slots. Is that something that's doable in intercon (acorn, most recent version of cnc 12)?
I don't have cnc12 in front of me now so I can't look around at the moment. The way I see it is either as a bolt hole pattern with pocket milling (under angle) if something like that exists or milling a slot and then looping while rotating geometry by 6 degrees in every iteration and I have no idea how to achieve that.
Thank you,
Bruno
Re: Milling ABS (pulse) ring slots in intercon
Can you upload a drawing?
Pencil sketch will be ok also.
bbatarelo
Post by bbatarelo »
Here we go.
This is easy to do.
Make one slot and use the rotate cycle.
bbatarelo
Post by bbatarelo »
Much obliged! Had no idea about that feature.
Bruno
