C97 gecko g250x
C97 gecko g250x
I can’t seam to get my c97 g250x to run my motors I have a bi polar motors a 2315hs300aw-ob from open builds 1/8 step I am trying to use wizard and anything that I try I can’t seam to get it to work any help would be appreciated thanks.
Re: C97 gecko g250x
Could use some more info, photos, and a report to be of more help.
Got your motor wire pairs correct, got a 48v power supply hooked to the C97, current set, wizard set to DB25 for signal mapping......?
Scott
Re: C97 gecko g250x
Are the motor drives connected to the DB25 plug!?
Re: C97 gecko g250x
Scott
